Originally Posted by alabama_lowlife
going back to greaseless after wetsanding is back tracking quite a bit. i only sand if the piece is kinda flat and has some uneven places.
the first couple months i was trying polishing, i didn't realize you had to let greaseless dry and it worked....ok. but after i read that i needed to let it dry, i realized how great the stuff is.
Thanks for the input. So maybe after wet sanding I could go straight to emery and tripoli, right? With the greaseless, do you just roll the wheel into it and let it dry? If so, how long do you need to let it dry?
Thanks in advance.
