Old 01-21-2007, 01:52 PM
jrow jrow is offline
Default Re: newbie question to blasting
Originally Posted by pklin
Hello all,
Trying to start out with a little benchtop blasting cabinet requiring approximately 5 CFM @ 80-90 PSI. I have noticed that a lot of the compressor found in home improvement stores don't match up to this requirement, unless you go up in horsepower and price which defeats the purpose of setting up an affordable, beginner home blasting hobby. My question is, if I got the aforementioned cabinet, and got a compressor that is rated at 4.2 CFM @ 90 PSI, how will this effect the blasting operation? I will be blasting mostly small parts, so I was also looking into pencil blasting cabinets that only require 1.5+- CFM at low PSI. Should I consider pencil blasting cabinets as solution? Thank you.
Try this web site it may help with your decisions. http://www.pablaster.com/
As a rule of thumb, the bigger compressor that you buy the higher the volume of air which is what you need to do effective media blasting. You may also consider that at sometime in the future that you may want to use air operated tools on your compressor. Now consider that you have your pencil blaster and now want to start blasting mainfolds or vehicle suspension parts. It will work! BUT because of the low volume of air you will have to continuly wait for the compressor to build up pressure in order to effective blast those parts.
John
