Re: cheap excellent material for oven walls
Just in case - a bit of clarification - while my oven in its original condition would heat to 200F, I was trying to abandon that given that I wasn't sure if elements/fans/etc could handle the 400+ PC temps. The 5200W I have installed is the only heat source for a 4x2x5=40sq ft oven. I'm also beginning to worry that even if it does dry out - will it again absorb moisture when not in use?
