Originally Posted by tweak
how do you guys do it?
im polishing items, they are very intricate but also large..... and a little rough, so they need sanding.....
what should i use to sand it smooth and polish the tight spots out
i hear the bobs with sanding stuff on em suck
This has been covered recently tweak. Do a little reading then ask again if you still have questions.
The bobs with greaseless compound work fine if you know how to use them, and there are a number of other good tools as well. All probably touched upon in the past month's threads.
