Re: Gold Plating Question
1. No need for a rectifier with Plug N Plate as a constant current at the set voltage is all that's required.
2. Increased amps will simply burn the part. Same kind of thing as baking a cake. Turning temp up from 250-700 deg will not speed the cooking. Several coats would be great.
3. Yes, that will be perfect. Very light buffing with a Canton Flannel wheel...you don't want to remove any gold from the piece.
