Originally Posted by Tng21
arrrrggggh, wish i had seen this before i went to bed, i opened one this morning and had a little go with it, spun it up on my felt bobs and covered it, dried it with hairdryer and had a go, very impressed. Was put in the shed but its like a firdge in there anyway
Really shouldn't let it freeze, either.
Can you heat up em with a hairdryer to make them melt a bit so u can just dunk the felt bobs in a runny gue??
I wish, but i doubt it. I tried to make a paste of it with water one time but couldn't make it work.
How about loading up loose mops? is that possible? Thinking along the lines of loose mops get into more creveses etc so maybe they would sand in more creveses?
Without a continuous surface it doesn't work so well. But with your smaller bobs you'll be able to get into most of the tight places. You can also use the razor wheels which are thin enough to get into a lot of areas.
