Old 02-01-2007, 05:02 PM
alabama_lowlife alabama_lowlife is offline
alabama_lowlife will become famous soon enough
Default Re: dremel polishing....
what are you trying to polish? unless it's already nearly at a polished finish, the white compound alone will not get it there. depending on the condition of the part, there could be many many steps up to and including sanding with 36 grit sandpaper. at the very least, using emory will likely be required.
