question
For you Guru's
im using a constant current 5 amp power supply i purchased from Caswell.
When Anodizing 6061 T6 Aluminum the "volt" meter will climb upwerds of 14 volts no problem.
When Anodizing 2024 T351 Aluminum the "volt" meter will max out around 9.2 volts.
is this normal? why wouldnt the 2024 voltage climb as high as the 6061?
