Old 02-04-2007, 11:37 AM
jrow jrow is offline
Default Re: Polishing Stainless Fuel Tank
35forddream,
If it were me before I put any sandpaper to the SS I would get a 4" Sisal buff and some Emory and see if that will give you a shine! After the Emory I would work with the SS compound, then to white, on a sewn buff. You can get a 4" Sisal buff that will mount in a drill motor and give you good results. An air die grinder will work providing your air compressor is big enough to keep up with the demand of the die grinder! You can very you air pressure to adjust the speed of the die grinder.
The areas that are welded together may require some sanding. I would try some 2" or 3" Roloc's in your die grinder.
John
