  #8 (permalink)
Old 02-05-2007, 10:28 AM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: Hobby-charger, swallow ac/dc2 ?
Use the 720 rule. If you go by PAR to end a run you will usually under anodize the part and not get a good dye. The run time is determined by the CD used for the run. A 1 mil coating takes 160 minutes at a 4.5 ASF CD. This is effected some by the material grade.
SS
