Old 02-05-2007, 10:36 PM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: Newbie needs some help to fine tune the process.
Your calculations are off a couple of places
Surface Area 55.75 In²
0.39 Ft²
Thickness 0.70 (0.1-1)
Current Density 12.00 Amp/Ft²
Set Current 4.65 Amp
Time 42.00 Minutes
Peak Voltage 30.00 VDC
A 84 min run time is for a 6 ASF CD with an amperage setting of 2.32A on the power supply. Basically you doubled the CD and ran it twice as long as needed.
SS
