Re: How to attach sheet metal to insulation?
twistedneck,
If the locker is metal, which I assume it is? i would put the insulation on the outside, so that you don't make the inside smaller. Your oven is going to be awful small as it is. I would suggest that you put a shelf in it so you don't have to heat it all at once. That would require you double your equipment so you can heat the top or bottom independently! Of course you could make a disconnect for one unit and accomplish the same thing.
John
