Old 02-11-2007, 04:30 AM
coyoteg coyoteg is offline
coyoteg
Default Are steel attachments damaged by anodizing?
I have a motorcycle clutch basket that has high strength steel pressed and riveted into the aluminum. There is no way I can remove the steel bushing and gear.
Will the anodizing process damage the steel? That is, can the battery acid bath damage the surface of the steel to the point where an oil seal will not work properly or gear teeth are damaged?
Thanks
Ken
