Old 02-13-2007, 11:14 AM
acidrain's Avatar
acidrain acidrain is offline
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: what went wrong?
If you've measure the surfaces correctly (all sides?), and set your PS to the correct amps, and maintained a good connection all the way through the run, it should have worked.
Did you monitor and record the volts during the run? That is a good way to know if there was a problem (lost connection) during the run.
Another clue is the racking wires... if you used aluminum wires, did they anodize and dye correctly? If they did, and the part did not, that would indicate a lost connection.
Regardless, always heat your dyes to 140F for best results. GL... try again.
I do things.
