Old 06-24-2003, 12:32 AM
marsfrogie marsfrogie is offline
marsfrogie
Send a message via AIM to marsfrogie
At the bare minimum, you will need the following:
-240 grit greaseless compound with a spiral sewn wheel.
-Emery compound with sisal wheel.
-Tripoli compound with spiral sewn or loose cotton wheel.
-For added luster you can use white compound on either a spiral sewn or loose cotton wheel.
For the intake manifold, you will need an assortment of felt bobs. Sanding tapers will make your job much easier on the intake manifold. I do not believe Caswell stocks them, but perhaps they could special order.
