  #8 (permalink)
Old 02-14-2007, 02:26 AM
nuttyman's Avatar
nuttyman nuttyman is offline
nuttyman
Default Re: Oven Glass Question
if you can't easily see the part just tack on an extra 5 mins. cure time. flow-out usually occurs around 5 mins after you place the part in the oven, from room temp. that is. however i recommend pre-baking parts before shooting to outgass so the part will be slightly warmer when you apply the powder.
