Originally Posted by edge4you
i am polishing a top triple tree on my bike, it is alum. has a kinda shine and some scratches
i was using a dremal but seems not to be working, should i use a drill instead of dremal and any other tips would help. also the triple tree is on bike and cannot remove it
Like UncleJimmi said, except that I would pick a small trial spot and go backwards with the grits...try say 600 grit first, then 500, etc. If you start coarser than you need to, you'll spend the next few steps trying to get rid of all those self-induced scratches.
I'd also try a fine Scotch-Brite pad first - if there's a clearcoat it might take it off better.
Use popsicle sticks, etc. with your paper or pads to get into the tight areas.
