Old 02-15-2007, 10:38 AM
kcenicola kcenicola is offline
kcenicola is on a distinguished road
Default Re: Solid State Relays
You only need to switch one leg of the elements 2 hot lines to make it turn off and on. But if you switch it this way make sure that your main on/off switch is a douple pole switch that shuts off both pwer legs to the rest of the circuit. So that when it is turned off, there is not 120Volts sitting at one leg of the elements.
