Re: just a little veiw of the eng.
Looks great Rich. With all that powder on the jugs, have you thought about at least dry film lubricating the pistons? I most likely would have sprayed thermal dispersants on the heads, valve faces, and piston tops as well. Also ceramic the inside of the pipes to draw some of the extra heat away from the engine. This will most likely not be an issue during highway riding, but in stop and go traffic it could potentially cause some problems, if you put alot of miles on your bike in city driving conditions.
