Old 02-16-2007, 10:42 AM
seanc seanc is offline
Zinc Plating Guru
Default Re: Zinc Plating & Amps Query
Cahrles:
Size disparity between parts is irrelevant. You simply need the total surface area of all parts combined.
eg, take a 9" part & a 1" part together. The 9" part will attract 90% of the current, the 1" part 10%. Each will get the same ASI.
You'll likely never need more than the 5-7 volt setting, as long as it allows you to set the appropriate current.
Sean
Seans Zinc Plating page
