Old 06-26-2003, 03:45 PM
mdarr mdarr is offline
mdarr
Default Power Supply Settings
I have a 10 volt 100 amp Hewlett Packard power supply. It can be set up for either constant current or constant voltage. Which do I want? Do I crank the voltage all the way up and then adjust the current to the desired level or do I crank the current all the way up and then adjust the voltage until the current is at the desired level? Thanks!
