Old 02-17-2007, 11:28 AM
JTW37's Avatar
JTW37 JTW37 is offline
Caswell Platinum Member
Default Re: Couple questions
If you look back through the past post, you can find a couple of wiring schematics. The only difference I have found is in the controller. Some are from the oven scavenged from, some are digital with 10 (like mine) and 12 connections. Once you see the main wiring schematic the rest isn't to bad.
I plan on adding some fusses in my circuit, to protect against any mislead electrical current.
