  #9 (permalink)
Old 02-17-2007, 02:15 PM
acidrain acidrain is offline
Default Re: newbi with ambition
Sounds like you've put a lot of thought into this... good work!
Yeah, the heat tranfer pipe thing will work for sure. My only concern would be the alloy of the pipe. I think it was 5051 that lasts the longest, but be aware, the aluminum is constantly being desolved into the acid. Thin-wall pipe will disappear after awhile, and if you spring a leak into your tank, it will be contaminated.
You might consider making a plate type heat exchanger made from 1/4in plate. It could be used as a cathode as well. Lead would be even better, and a titanium one would be the shiz.
