Old 06-26-2003, 09:55 PM
PC101 PC101 is offline
PC101
Default What am I doing wrong here
Here is what I'm trying to do, I am coating pieces in chrome powder, then trying to second coat this with a translucent top coat. My attempts at this have been very unsuccesful. I have tried this several ways. such as:
I have coated the base material in chrome, put in oven until part flowed out, then let it cool. after it cooled I tried to coat it with my top coat. the powder did not want to stick to the part evenly, results horribly blotchy.
2nd I tried coating with the chrome powder, curing until it flowed out, removed from oven then while still hot/warm tried coating the part with the topcoat. still powder would not coat evenly, but better than first try. results blotchy
3rd I new this wasn't going to work right from the beginning, but had to try
I coated the base with the chrome, then with out curing, top coated. of course this didn't work like I wanted, But it did come out with a neat marble effect. Results, interesting, but not what I wanted.
What I haven't tried, is coating the base, fully curing, then trying to topcoat.
It seem like when I try to put the top coat on that there is no static charge, or very little charge.
my next attempt will be, as follows. I enlarged the hole that I was hanging the part from, tapped it for threads, put a bolt into, in hopes that I will get a better electrical connection from the ground. Which I hope will increase the static charge.
Any tips or suggestions will be apreciated. Other than the problems putting on a top coat I'm impressed with the way things are turning out.
thanks to all that help
Ron
