  #22 (permalink)
Old 02-18-2007, 10:19 PM
kcenicola kcenicola is offline
kcenicola is on a distinguished road
Default Re: My oven SCHEMATIC...for new oven builders..
In older houses, the Neutral and The ground wires are all tied to to the same terminal strip back at the main box. In newer houses the grounds are tied to a terminal that goes to a spike in the earth and the Neutral's go back to the telephone pole outside your house.
The problem with the older setup is that when people are wiring a 240V circuit and they only have 3 wires to connect to their device, they don't take the time to ground their device to the Neutral. So if there is ever a short circuit between one of the 120V hot legs and the device (oven) the oven becomes charged an becomes a shock hazard. If the oven is attached to the Neutral, if there is ever a short between the oven and one of the hot legs, the circuit breaker will trip.
When they changed 240V receptacles to have 4 wires, this forced people to attach the green ground wire to your device to protect against this.
KC
