Re: Duplicating look of bright dip
Bright dipping typically refers to removing the metal oxides from the surface, as well as dissolving the "peaks" of the surface to match the "valleys", producing a smooth highly reflective finish. This can also be done by mechanically buffing and polishing the metal until you get the same result. You need to start with a fairly rough buffing wheel or sandpaper, then increase the grit number to polish grade. Need to wet sand if using sandpaper. If using buffing wheel, use appropriate buffing compounds (from buffing compound to polish compound).
