  #9 (permalink)
Old 02-18-2007, 11:18 PM
gourdhedd's Avatar
gourdhedd gourdhedd is offline
gourdhedd
Default Re: Couple questions
Originally Posted by RobsPCing
So now the next question is how do i wire it up to my contactor? And in your wire box is your on/off swith just a regular 110v 2 pole switch? It's starting to make sence alot more now.
Connect a wire from one of the incoming 110v lines, route it through the switch (yes, just a regular light switch), through the contacts on the t-stat, and then to one of the coil contacts on the contactor. The other coil contact gets wired back to the neutral. Turn on the switch, set your temp, and the thermostat will cycle the contactor thus turning your elements on and off. This assumes that you have a 110v coil on your contactor.
Gary Brady
www.powdercoatoven.4t.com
