02-19-2007, 08:44 AM
Re: Clear Coat - What to?
Originally Posted by itsallgood
When doing solid colors is there any colors that you shouldn't clear?
(Making sure your using a gloss clear for gloss colors, etc.)
To apply clear is the below how to apply it?
Cure base solid color fully
Remove part
Shoot clear @ 150*
Fully cure againThats the way I do it.
If you have already coated something and it's been a couple of days and it hasn't been used or handled can you re-heat and shoot the clear at that point? Yes you can do this too just be sure to clean again I use denatured alcohol for this step. Make sure to clean a spot for the ground also.
Thanks in advance...
Jason
www.autocyclepc.com
