Old 02-19-2007, 01:11 PM
cprocess cprocess is offline
cprocess is an unknown quantity at this point
Default Re: removalable masking agent?
You can use teflon tape or vinyl tape. It must be rated for "high temp" since electroless nickel operates around 190 degrees F. They also market a tape called "platers tape". You can also use a brush-on or spray-on plastisol-type material. If you have holes you want to mask, you can use elastomer plugs.
