  #28 (permalink)
Old 02-20-2007, 08:27 AM
mpierich mpierich is offline
Default Re: Aluminum Valve Cover Question
Originally Posted by ptim
Pics of the pits.
Should I continue working on them, or is it a lost cause. I'm thinking about Powder Coating them White, to match my Oxford White Mach 1.
Holy cr@p, that's the worst case of the pits I've ever seen! You're done polishing, that's for sure.
There may be some kind of hi-temp filler you could use before powdercoating, but if the outgassing continued it prolly wouldn't work.
It's my understanding that these could be filled with a (few?) layers of copper, ground smooth, then plated, if that's the route you wanted to go.
