Old 06-27-2003, 03:25 PM
tgoode tgoode is offline
tgoode
Default Pot Metal is driving me nuts!
I am attempting to strike plate some pot metal parts using Flash Copper in preparation for electroless nickel plating. My prep work on these parts has been:
-Sandblast with silica sand paying careful attention to pits to ensure they are free of oxides
-degrease with a soak in naptha (5 minutes)
-degrease with a soak in acetone (15 minutes)
The plating conditions are:
-Dip plating in flash copper @ ~130 degrees
-600 mAh transformer
-2l of solution
-3 square inch anode
-approx 10 to 12 square inches of surface area to be plated
-Anode is approx 4" away from the parts
-Plating time was 10 minutes
I am getting "flowers" of some kind of whitish oxide forming on and growing out of the surface of the parts. Beneath the oxide the part is blackened, pitted, and not plated.
I have successfully plated this alloy using the pot metal primer in the past. I have switched over to Flash Copper with the understanding that it provides a superior strike coat.
Am I doing something wrong?
Is the temperature causing this?
Could this be the result of surface contamination by the Acetone or Naptha?
Would boiling the parts in distilled water prior to plating help?
Should I zincate the parts first?
