Old 02-21-2007, 08:30 AM
mpierich mpierich is offline
Default Re: How long does it take greasless to dry?
Originally Posted by alininger2001
So dou you have to load it up more that once before using it? If so how many times?
On small bobs or wheels I usually use three coats; on 8" wheels, two. The more coats, tha longer you can go between loadings. You need to make sure a layer is completely dry before applying the next.
Also, with felt bobs I usually use a hacksaw blade or sharp knife to make lengthwise cuts around the bob (not too deep) - it gives the greaseless a way to stick better.
Additionally, when I use felt bobs with regular compound, I clean them with a hacksaw blade or 80-grit paper.
