Old 02-21-2007, 11:24 AM
Popeye Popeye is offline
Default Re: 50kv not working
I'm sure you'll run into small problems with just about anything... Did you happen to talk to Caswell about this?
If the powder doesn't stick it does sound like a ground.. do the LEDS light up when you hit the pedal? Does it arc to the ground cable?
