ground issue is what i was thinking, that was the purpose of tapping the hole and using a bolt instead of a hook, that way no powder could get into the hole.
I will try your method. You mentioned that you reduce the voltage by 25% for the second coat. 1) what do you reduce the voltage to since I don't know what your starting voltage is and 2) What does that do for you? just trying to pick as many braincells as I can.
thanks
