My intentions, however weird is to consolidate oven and spray booth into one structure. Fans to suck out powder in spray mode not to regard any powder reclaimation, then to slide in elements for heating once most all of powder is removed. Oven is 4' X 8' x 36" allready partially assembled.
Oven is designed to reach 800 degrees for any possible use of ceramic coating for use on Hot Rod Pipes etc. Heat range to be reached by infrared and electric elements. I believe this is doable.
dealerlvw@yahoo.com
