  #12 (permalink)
Old 02-22-2007, 02:06 PM
mpierich mpierich is offline
Default Re: Dumb question of the day: Read here
Originally Posted by Cub
This doesn't seem to be working. I am trying to apply the black but it powders off or melts away from my wheel?
It's on the wheel whether you think you can see it or not. A 2-second jab onto a spinning wheel every few minutes is enough.
....Is there a step by step with pics somewhere? I had better luck with my **** setup than the kit.
There are videos about polishing. Not sure if Caswell has one but they're out there.
.... I need more abrasive to get between the runners on an intake and this isn't right. Wrong materials?
What stage are you at with the intake? Have you sanded it up to at _least_ a 320 grit? If you're truly at the emery (black compound) stage, it doesn't take a lot of compound to do the polishing, and less compound for subsequent steps. To get between runners I have to use felt bobs, small wheels, mushroom wheels, and a variety of other tools.
If this was easy, there wouldn't be a market for our services.
