  #13 (permalink)
Old 02-24-2007, 10:31 PM
JTW37's Avatar
JTW37 JTW37 is offline
Caswell Platinum Member
Default Re: Any ideas for a door latch?
Yea, I guess that needs to be said. I do have a frame work for my entire oven. So it wouldn't be an issue with mine. But if you don't have a frame around your door, you could add a plate to the door and use that for reinforcement. Of course you would want your door to fit pretty good and not bind when closing it, so it had a lot (gap) to pull closed.
I did check out the one on ebay, but my oven with the wheels stands 6'2" and would be a pain to use that one. Am continually brainstorming and may come up with something better.
