Originally Posted by nuttyman
how is the main switch wired that allows power to the whole system? does it carry the whole load?
All of my low voltage is run through the main kill switch then to the fan switch, the light switch, and the controller, and is fed by a dedicated 15amp breaker and 14ga. wire (total amps here should be less than 5). The load wire from the controller then goes to an element kill toggle so that I can leave the controller on, reading oven temperature, after shutting off the elements. The load wire from that switch then goes into the 3-pos. lever switch so that I can choose the elements I want to burn. From the lever switch the load wire will go to one side of each of my contactors' coils.
To answer "does it carry the whole load?" - No, just the low voltage for the fan, light, controller, and contactor coils. The main power for the elements come from their own breakers to the contactors. Hope I didn't confuse anyone.
Here's a pic of the inside (unfinished).
