  #14 (permalink)
Old 02-25-2007, 11:49 PM
schema schema is offline
schema is on a distinguished road
Default Re: Silly Q on home made chiller, improving cameraman's design
Originally Posted by Tim Wiltse
That's the thing. It's a mute point if the pump in this setup can handle acid or not. All the thing is pumping will be water.
LAter,
Tim
bingo, i never planned on circulating the acid, just cold water through the pipes, thus cooling the acid.
I'm going to rebuild an aluminum set up this week. I won't bother taking calculations on the PVC set up, but I will on the aluminum one. Later in the game I might tear apart a small fridge and see if I can make this thing a "set it and forget it" , instead of dumping ice in the water all the time.
I'll keep ya guys posted
