Thread: Oven metal
Old 06-29-2003, 11:04 PM
DALE DALE is offline
Many variables to figure.I don't know what you have available to you or your buying arrangements with suppliers.The simpler you make it the cheaper it will be, common sense<. But fair guess not knowing these things would be between $200 to $600 dollars. If you go about right it might be a bit less or you could go nuts and spend thousands of dollars.
