Re: Flash Copper Problem
Ken,
Thank's for your good information on the flash copper. Everything you said sounds like good stuff. I am getting ready to order the flash copper material from Caswell for the first time, so your advice is very timely.
Can I ask how you determine if you have under 60ma/sq.in.? What kind of reostat set up are you using? Do you use a six vlt system to plate with? Is the copper a little more forgiving than the copy chrome?
Phil
