Thread: hard anodizing
Old 02-28-2007, 01:28 PM
rclint rclint is offline
rclint is an unknown quantity at this point
Default hard anodizing
I know it's not supported, but I want to try a 10/22 cast receiver, and all I expect is black or OD green for color
Any opinions, tips would be appreciated. I read the sticky at the top, I have a over sized chiller and running around 16 gallons total tank size. Pump is 1200 gallons per hour, and I imagine I'm prob getting 800-1000 in just agitation alone so I think I have that covered.
The part to do is small enough I can should have no problem with my power supply, acid ration wil be my biggest pain, I can add enough to make the solution 1:2 no problem, I guess when I go back to 1:3 I could then just correct the mixture and put the saved in some jigs for when I do a solution change
I would like to hear from anyone who has tried this method, I know it's not needed, but I want to see how it works on cast, and also just like to be different I reckon LOL
Clint
