Large tank that is temperature safe
Hello all!
I'm a Newbie here, just curious as to wether there are any cheap tubs or totes out there that can withstand the temperatures of boiling water and what you may have used for larger items, such as sheet metal aluminum panels? I am building a Kit car and it has a large number of aluminum panels that I want to coat, some are as large as 48" by 36" (the largest one) everything else would not be a problem, just wondering what some of you might suggest I use for a larger tank for anodizing.
Thanks in advance!
Ben
