Old 03-01-2007, 04:19 AM
Banditperformance Banditperformance is offline
Default Re: Have some pricing questions.
Rear axle housing, 1 color I charge $105. CHrome needs a clear, I add 50% of the 1 color price for second coats. This applies for candies, adnything that requires 2 coats or more. 50% each coat. Degreasing/Sandblasting is extra. Phosphating is usually included, unless it is a extremely large piece. And I would get the bars sandblasted too. Even if they are new. Alot of machining oils in new metal, and blasting gives the powder exxcelent tooth to hold on to. It like to flake and peel off new, unblasted metal. That's the reason why alot of factory parts peel, like ATV parts, they don't blast them. Oh, I'd probially charge $15 per bar, depending on size.
The front end, best to see it first, but I'd say 175-250, depending on how many tight nooks and crannies there is. Nooks and crannies are harder to shoot. It too should be sandblasted. Any undercarrage/suspension part that is subjected to the elements and road spray needs to be blasted. Phosphated as well is even better.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
