pregnant oven
After much thought and a project just shy of a small oven and no way large enoguh for a large oven i have come to build a pregnant oven. I used a very good source off the board to help me. You know who you are and thank you. After about three hrs of talks i have a list of stuff for a lowes run. It is as follows:
1 switch box (this will be to turn off the second element when not needed)
1 flexable conduit package
2 extra conduit ends (plastic and goes into the switch box)
1 30A 220V switch
2 fence post tops
2 90* conduit bends (metal)
2 pcs of flat stock (elevates the element)
10 small l brackets
1 bag of 1/4x20 nuts and bolts
3 conduit holders
4 pcs of foil duct board
3 pcs of drywall cornerbead
3' of high temp wire 12/2 with ground
8' of regular wire 12/2 with ground
1 tube of high temp silicone
1 roll of foil tape
at the bottom is a zip file with this list in an excel spreadsheet for you to print out and price everything out.
As i get the stuff together and build i will be posting the pics. I am pretty sure this would be a good list to take to home depo or lowes but i in no way take blame if you choose to use this info and hurt yourself or your property.
