Re: pregnant oven
more pics.......
the first shows the wire cluster under the metal cover.
THE second shows the broiler element feed wire from the termastat cut and the bake element wire cut and the broiler element disconnected. I am going to nut the two wires together to get the 220v to the bake element. Then i will run another wire teed into these into a junction and feed the broiler element that was moved to the door.
