Thread: Preparation
Old 03-09-2007, 01:26 AM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: Preparation
Originally Posted by vertek
Everywhere i c that you should use pressure blaster's,
Would this one be ok ? http://www.columbiacoatings.com/1152...5erfrg5467.htm
What type of compressor should i get to be able to use that and can i use the same compressor for powder coat gun ?
its just that I dont want to be landing out $300 or more for a compressor.
Thanks.
Seb
link doesnt work its the 40lbs one
pressure blaster is usually for larger parts or parts that have a heavy coat of paint to remove. if you only need to remove small layer of paint or just to prep the part then a suction blaster is fine wich needs a smaller compressor to use
baz
http://www.polissagepb.com
