Thread: No Plating
Old 07-03-2003, 11:58 AM
48Buick 48Buick is offline
48Buick
One thing to check is to make sure you have the POS on the anodes and the NEG on the part. If that is right they I would suggest to try this procedure.
Dont use laquer thinner. It still leaves a film on the part.
Degrease(remove buffing compound) with hot water and dish soap.
Rinse.well under hot water then cold
Clean in the SP cleaner or a alkaline cleaner.
Rinse well under hot then cold water.
Make sure the water sticks to the surface of the part and doesnt bead up and roll off like water on a good wax job.
If it does bead up....scrub the snot out of it again!
Then plate....
Hope this helps
48 Buick
