Thread: My oven 4x4x8
Old 03-09-2007, 09:30 PM
mtumbleson mtumbleson is offline
mtumbleson
Default My oven 4x4x8
Oven front with 2 windows (4 panes of glass per opening)
http://www.lukescustoms.com/Oven_front.JPG
http://www.lukescustoms.com/window.JPG
Access panels. These are used on both sides and the back so I can get to the wiring with out having to remove the entire panels. They will be screwed on instead of rivited.
http://www.lukescustoms.com/access_panel.JPG
This is the door latch assembly.
http://www.lukescustoms.com/door_latch.JPG
The door weighs rith at 200 pounds. I didn't want all that weight hanging on the hinge all the time. I cam up with this to help support the weight.
http://www.lukescustoms.com/door_support.JPG
http://www.lukescustoms.com/Oven_door_support.JPG
Here is the fan mounted at the back of the oven. It pulls the air from the top of the oven then is directed to the bottom of the oven through a duct inside the oven.
http://www.lukescustoms.com/fan.JPG
Inside the oven, at the top is the inlet to the fan, the black part is the duct returning the air to the inside of the oven.
http://www.lukescustoms.com/Inside-_fan_ducts.JPG
This shows the 2 interior lights and the air duct releasing the air 1 foot from the bottom of the oven. The Idea of running the return air down the inside of the oven is that it will be re-heated on the return. I do loose a little area inside the oven, but I think this will work fine.
http://www.lukescustoms.com/inside_oven.JPG
Picture of the Panio Hinge
http://www.lukescustoms.com/Panio_hinge.JPG
This thing is sitting on casters so I can move it around my shop.
It is built with 18g gal. inside and out.
All I have left to do is purchase my wire and ss wire conectors the hook it up.
Hope this helps someone with their build. All the parts used were from information found here on this forum.
Thanks for all the help.
