Originally Posted by baz
pressure blaster is usually for larger parts or parts that have a heavy coat of paint to remove. if you only need to remove small layer of paint or just to prep the part then a suction blaster is fine which needs a smaller compressor to use
suction blaster? a local parts store sells ones that work with your vacuum. seems far from ideal. can you post a link to one you would recommend?
